Question about Miscellaneous
Hi we have a work zone demolition breaker TT-DH1600 does it require oil to be showing in the site glass?? If so where do you add oil. Thanks
  • 18,139 Answers
5 Suggested Answers
6ya staff
SOURCE:
Editor925
Dean
  • 285 Answers
SOURCE: what type of oil i will luricate to my makita HM
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Posted on Feb 25, 2010
Anonymous
  • 6 Answers
SOURCE: zoning not programmed
Hi ill be honest this is a little tricky
There are many variations depending on a few things.
Is it heating only or add on refrig as well?
Is there a common zone or an area constantly open?
How many networker controls 1 or 2
So any way this is the set up for heating only 2 zones and common zone.
Turn the networker wall control off
in the off screen press the clock key (the time will flash)
hold down the 2 & 4 keys for about 5 seconds
depending on the model and what other appliances are lincked to it it will display either
H01 ID01 1500 (NC3 2004 onward)
1500 01 H01 (NC1&2 pre 2004)
press the (M or mode) button till you get to the N1 parameters eg N1 ID01 01
press the number 1 key or on older models top key
should then display should read
N01 ID15 01(COMMON ZONE)
Then using the dial to change the setting to read the same as below once done press the number 1 key or top key to advance to the next setting
N01 ID16 01(NETWORKER NUMBER)
N01 ID17 01(ZONE A)
N01 ID18 01(RELAY NUMBER ZONE 1)
N01 ID19 01(NETWORKER NUMBER)
N01 ID20 02(RELAY NUMBER ZONE 2)
N01 ID21 01(NEWORKER NUMBER)
then press the number 1 key followed by the on off button then, provided its all been installed correctly zones should appear and operate :-) good luck and i hope this helps.
Posted on May 16, 2010
vestxre
  • 119 Answers
SOURCE: where exactly do you add the oil for the hobart
The piece that the front screw in the top cover was screwed into is the filler plug for the tranny.
Posted on Apr 14, 2011
angusmeads
Angus Meads
SOURCE: Which oil should be use in a demolition breaker hammer
Hydraulic
Posted on May 16, 2017
What is the correct procedure for checking the oil level on a 1997 honda slr 650.Thanks in advance.
Hi Anonymous, many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
1. Bring the engine up to operating temperature or let idle for 5 minutes.
2. Turn off your engine and let it sit for 2 minutes, this will allow the oil from the top end to drain to the bottom.
3. Hold your bike straight up or on the center stand and wait 2 minutes for the oil in the bottom of the engine to be level in the sight glass.
4. Your oil level should be between the top full mark and the bottom add mark.
5. Never over fill your oil system it will cause problems:
a. oil leaking out of exhaust pipes.
b. oil leaking out of breather pipe/hose.
c. oil carryover into the air cleaner.
6. Your oil site glass must never be completely full drain as necessary.
7. Your oil site glass must never be completely empty add as necessary.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
XR650L oil level when cold
XR650L Oil and Filter Change
http://d3sty.eu/shadock/temp/Honda_SLR650_Servis_manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 26, 2017 | Honda SLR 650 Motorcycles
I have a 3600w arksen jackhammer. It does not have an oil site gauge on it that I can see. what do I do about adding oil to this unit?
all these types of jack hammers hammers use 40 w oil
its electric
cant find a user manual for it online
if no visible site glass or oil filler
whats the chances you have to undo part of the jack hammer
at the Allen key bolts
reviews say these arksen units leak oil often
Jul 20, 2016 | Cars & Trucks
2010 Kawasaki KX250F where should the oil level be on the site glass
Hi, Tayler if you are experiencing excessive oil coming out of the crankcase breather or air filter please drain all engine oil and replace half of the same oil that comes out. Many riders are overfilling their oil system because they do not know how to properly read their oil site glass or dipstick. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should refer to your owners manual. Use your center stand if you have one.
3. Hold your bike straight up or on the center stand and wait 2 minutes for the oil in the bottom of the engine to be level in the sight glass or on the dipstick.
4. Your oil level should be between the top full mark and the bottom add oil mark.
5. Never overfill your oil system it will cause problems:
6. Your oil site glass must "NEVER" be completely full or empty drain or add oil as necessary.
7. Your oil dipstick must "NEVER" be over the full mark and should never be below the add mark drain or add oil as needed.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New 2012 KX250F Oil not showing up in sight glass
Oil sight glass KawiForums Kawasaki Motorcycle Forums
Kawasaki KX250F Service Manual
OEM Parts for Kawasaki
Kawasaki KX250F Owner Manual
Jun 26, 2012 | 2010 kawasaki KX 250F Monster Energy
Xt660x not showing oil level on dipstick
Hi Anonymous, many riders are over filling their oil system because they do not know how to properly read their oil site glass or dipstick. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should refer to your owners manual. Use your center stand if you have one.
XT660Z Dip Stick Oil Level Low XT660 com The 1 XT660 Resource
Adventure Bike Rider
Yamaha XT660R Service Manual
OEM parts for Yamaha
Yamaha TENERE XT660ZA Owner Manual
Feb 25, 2012 | 2009 Yamaha XT660X
How much oil should i add to my 1981 xj 750
Hi Kyle, many riders are over filling their oil system because they do not know how to properly read their oil site glass. The following procedure works on nearly all 4 stroke engines but to be on the safe side you should always refer to your owners manual. Use your center stand if you have one.
Just bought 1981 seca 750 OIL CHANGE HELP
1982 Yamaha 750 Maxim Oil Change with middle gear drain plug location
Yamaha XJ750 Owner Manual service manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Oct 30, 2011 | Yamaha Motorcycles
What type of oil i will luricate to my makita HM demolition breaker
Feb 25, 2010 | Makita Hm1500b 42-pound Demolition...
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
The 2 site glasses on my yamaha fzr 1000 1990
I'll post a link for you to get with other dudes that own your same bike. Should have it up by friday night, if not tonight. Thanks for getting back to me. Will let you know why there are two glasses right away. TT
Feb 06, 2009 | 1990 Yamaha FZR 1000
Oil compasity
Hi! Have you found the sight/inspection glass near or around the oil filler or clutch cover? it is a small round piece of glass with two level bars half way up the side. After draining the oil (10/40 15/40) synthetic's best.
Keep the bike upright and slowly fill with oil watching the sight glass(Possibly with a torch) until it comes half way up then your done. Other than that if your oil cap is the type with dipstick/level carefully do the same as above until required level is shown on stick.
Hope this helps.
Paul 'W'
Onyer~EDson(:0)~[><
Dec 15, 2008 | Yamaha TT-R 250 Motorcycles
Miscellaneous Logo
156 people viewed this question
Top Miscellaneous Experts
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
