If I disconnect the pump the washing machine works fine up until the water needs draining but the spin cycle never activates because the pump is always on and never clicks over
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk. Once emptied it worked a treat. Pull the flap down and turn the large knob anti-clockwise and pull to remove. Good luck.
SOURCE: Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
SOURCE: Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
