Question about Panasonic Cameras
Panasonic mdh 1 is out focus auto mode - Panasonic Cameras
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Focus not sharp
you are sure its on autofocus mode....
Aug 05, 2009 | Panasonic AG-DVC30 Mini DV Digital...
Panasonic lumix DMC-FZ10 at least 5 years old no longer focuses
There is a switch AF/MF to set the unit to auto focus/manual focus, try to set to AF mode.
Here is the link of the manual
http://service.us.panasonic.com/OPERMANPDF/DMCFZ10.PDF
check page 65
Apr 03, 2009 | Panasonic Lumix DMC-FZ10 Digital Camera
Focus problem in my Panasonic MD 10000
can´t get the focus right I have tryed both auto and manual.
The zoom function is set to analog only.
Maybe there is some computerprograming that can help
Mar 21, 2009 | Panasonic NV-MD10000 Camcorder
DMC-FZ7 problems
Have you tried switching the mode dial to a flower icon?
The mode with the flower icon is the macro mode, you can shoot up to 5 cm from the subject.
Also, if you are very close to the subject, then the auto-focus may not function properly if the targeting area is not centered on the subject.
When I shoot macro with my FZ7K, I use manual focus, the auto-focus generally has trouble focusing up close.
I would suggest trying manual focus.
Jul 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
How to use auto timer
1. Turn on the camera in picture taking mode.
2. Now press the left arrow button.
3. Select the timer duration with the up and down arrow buttons, then press MENU SET.
4. Aim the camera, focus and press the shutter button. You now will have either 10 seconds or 2 seconds before the camera takes the picture.
Jul 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camara problem
Auto focus is supported with AF-S and AF-1 lenses only.
A mode switch is on the lens ,it should be in A position to activate auto focus.
In the menu select auto focus
Mar 24, 2008 | Nikon D40x Digital Camera
Photoes are not sharp
Hi, I have never had focus problems with my FX7. I suggest you set the AF mode to 1-area-focusing. This mode is quicker than the 9-area-focusing. To eliminate any possibility that the blurry photos are caused by camera shake, I also suggest placing the camera on a tripod (or setting it down on a flat surface) and using the self-timer to release the shutter. At this point you can also turn off the image stabiliser. A well lit outdoor subject is probably preferable for this test, as low contrast scenes sometimes cause the auto focus problems. If the photos under these conditions are still blurry, then you probably have a defective autofocus. Otherwise...
Sep 04, 2005 | Panasonic Lumix DMC-FX7 Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Cameras Logo
83 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
