I'm printing on a plastic label material, not a paper label.
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
SOURCE: Datamax I-4208 not printing allocated amount of labels
Try printing 200 at a time, anything over that and it will cause the printer to skip numbers or overheat. 200 (with a 10 second delay) at a time may take a while longer, but it its much better to start over due to number skipping or other errors. I can account to this since we do inventories and we are asked to print 50K+ labels, and any time we want to save time by printing more only causes us more problems.
SOURCE: Datamax M-4208 label printer is not printing. It
probably a bad or very dirty sensor - use compressed air to blow out the sensors (look in the user manual to locate the sensors)
SOURCE: datamax m 4208 thermal label printer.
Check out this link. It doesn't seem to have the solution, but you could call their tech support. the number is in the link.
http://www.datamaxcorp.com/support/tech/mclass/
