SOURCE: Beko DCC4521
On Tuesday this week I had the same problem, purchased a new element, followed the instructions from Apprentice & my cooker is now working again to the delight of my wife & for saving me about £300. Thanks
PeterB
SOURCE: beko s512 oven wont heat up light not on hob works
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
SOURCE: Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Testimonial: "thanks ashburton i will attempt to change the element first."
