Just changed internet service from Verizon to Cox and Alexa echho says shne cannot connect to the internet. She says to go to the Help section of the Alexa app. What do i do?
SOURCE: yahoo mail and Outlook
Go back and reconfig your Outlook Express and dont forget to delete the previous configurations in fact delet everything and start again. You need to go to yahoo to check what knid of settings they use.
SOURCE: changed from DSL to cable
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
SOURCE: hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
SOURCE: inspiron 6400 wirless connection
HI
If the browser shows working offline and wireless is connected fine then it could be an issue where work offline is checked in the browser.
In internet explorer 6 its found on File in the menu, if work offline is already checked, check it again to remove the check mark and then try, if its internet explorer 7 its found on tools, the same steps and in firefox under file,
Also try this step as well, if its internet explorer go to tools-internet options-and in internet options-go to connections tab-there is dial up and networking box-remove the dial up connections from the box-and check the one never dial a connection
also check the firewalls and antivirus programs, post your results.
thank you
rakesh
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
