Sounds like timer circuit. Roper Washer Parts Same Day Shipping Millions of Parts Here's a parts house.
Roper RTW4440XQ 2 speed washer won't agitate on low speed, gentle cycle, everything else works. not timer. [email protected]
SOURCE: Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
SOURCE: I want to open my
This unit has to be worked on from the back or under it. Most of the time that I had work on the pump for drain issues I would tilt it back against the wall and lay under it.
Here is a website (link below) that will show pictures of the break down to help you understand where the components are located. When you get on the website click the pictures on the left side bar for the different views.
I hope this helps.
GE Old Breakdown
