How do I run channel auto scan on Sansui Tv?
SOURCE: Initiation
Yoiu should be using the video output signal from your satellite box, not RF cable, to get the full benefit of HD program to feed the video input of your TV. Please resd the instruction book on how to hook up satellite setup.
SOURCE: When setting up a new
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
SOURCE: it ask to please run channel auto scan
just press the key that displays on the screen when it ask run channel auto scan or go to menu and channels find auto scan then press enter
SOURCE: Will not set tv channel to 3...keeps telling me to please run channel auto scan
You can do it manaly.
SOURCE: no pic please run channel auto scan
my problem turned out to be a wrong input. 2 days of frustration
I really did think i had it set right so i double checked.
