SOURCE: bathroom stall shower
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option. Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
SOURCE: vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
SOURCE: Leak in hand held hose, Delta In2ition
you must be missing a washer or gasket that goes in the hose end, of the hose try teflon tape,this is all your plumber is going to do.
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
SOURCE: The 'boost' button on my
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Testimonial: "Very helpful reply thankyou"
