Can not find much here but it seems like the air filter is pluged
Kenwood inverter 1 ton, error code 19. Plz let me the solution if any one has idea?
My kenwood 1.5 ton inverter ac is flashing 15 on display after i turn it on and no cooling
My inverter outer is not starting pls suggest any solution
It trips on 12 amps? Does it trip the breaker?
Hey everyone... i have kanwood dc inverter.. its cooling, but not heating, on heat, when power on the unit, it's start heating but it takes 10 amperes and then reaches to 12 amperes its trip. please help
SOURCE: Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
[email protected]
SOURCE: Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
SOURCE: Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
SOURCE: Fujitsu inverter air cond. just stopped working pr...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
SOURCE: Hitachi DC Inverter (heater/air conditioner) -
Down load free or cost basis your required manuals:
SERVICEMANUALS @ COST
www.mauritron.com
Manuals at free download:
homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Babar ali bhai same position here.mera b kenwood 36wala prob kar raha hy.plz aapnai kesy solve kia prob.plz rep
same problem here please help
How to correct this?
Mere 20 error a rha h display pe plz koi bta skta h lese thk hoga
Same problem how to fix it please help
My Kenwood DC inverter Air conditioner compressor didn't start and shows number 36 after 3 minutes on indoor unit digital display.
Plz Help????
display show on 36 what is 36 erorr?
Same problem my ac DC inverter
Yes same problem
mera kenwood dobara say wohi madla karny lag gya 36 wala.ek season sahe chala. bus.us k baad khaear he khawar kia. is nai
Ma Kenwood Ac Dc Invertor Modelkdc-1813s Is Displaying 36 Eror Code . What Does Mean It.. What To Do Now
Bhai mera bhi yehi problem tha
Indoor se outdoor main to wire jarahi hai wo change karo hojaega theek
My kenwood 1.5ton inverter ac is showing error 15 on display. Whats this problem
Salam.....Bro Kenwood inverter ka out door 9-10 hrs chal kr bnd hojata hy..kabi kabi bar bar bnd hojata hy ..KIA msla ho skta hy??plz guide
