Question about Sennheiser Audio Players & Recorders
Sennheiser mm 100 wont switch on - Sennheiser Audio Players & Recorders
2 Suggested Answers
6ya staff
SOURCE:
mudweed
SOURCE: Can't turn off the Sennheiser
A faster solution is to plug in the charger for a second and that will reset the led.
Posted on Feb 17, 2013
How do you repair a sennheiser sk100 jack socket
I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
May 01, 2014 | Sennheiser Audio Players & Recorders
What would it cost to repair the on/off switch on ew 100G2 sennheiser ?
To repair the on/off switch of the handhelt it would cost abt 15 minutes and $2,00 for the switch.
So that would be $20-25.
Reagrds Gerard
Oct 03, 2010 | Sennheiser 100/500 G2 Series Wireless...
Mini jack (3.5 mm) wiring schema. Thanks
Call Sennheiser. They have the wiring for their products.
Sep 18, 2010 | Sennheiser freePORT Wireless Instrument...
WHAT PLACE repair ew 100 micro, d ON/OFF switch
You're local Sennheiser dealer can fix it, no problem.
The repair takes a half an hour.
Regards,
Gerard
Mar 04, 2010 | Sennheiser Audio Players & Recorders
Sennheiser MM 50 iPhone Mic & Button does not work
I had just the same problem and if you're lucky, the solution is very simple: due to the open headset-plug of the iPhone I had a lot of dust inside. Just try (carefully!) to get the dirt out of the jack with a pair of tweezers or a strong vacuum cleaner. In my case it solved the problem. Good luck!
Apr 16, 2009 | Sennheiser (MM50) Headset
Broken On/Off Switch
Yes, the switch is available from Sennheiser parts, and if you can get to it and know how to work with SMD's, it's quite easy.
Mar 24, 2008 | Sennheiser SKM100 Wireless Handheld...
32 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
