Question about Sennheiser Audio Players & Recorders
I have the Sennheiser TR120 wireless headphones. I can get sound out of the right side only. Batteries checked 1.4 volts. Why no sound from right side?
    Top Expert:
  • Sennheiser Master
  • 30,346 Answers
You question contradicts
Usually with headphones, it is a broken wire as they are very fine. Remove the ear pads and then get inside them. Or return them for service.
Posted on May 06, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Posted on Jan 21, 2008
Anonymous
  • 3 Answers
SOURCE: unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Posted on Mar 08, 2008
JustPatrick
  • 7 Answers
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Posted on Apr 02, 2009
Anonymous
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
Anonymous
SOURCE: connecting wireless headphones
stop connecting
Posted on Jul 06, 2009
Suddenly no sound.
yes they do, if its connect via usb cord to pc or wall wort
does no sound cause from no power light (blue light on right side) if so you might have bad batteries this has happened to me before , there not user replaceable either bummer
May 07, 2015 | Sennheiser HDR 180 Wireless Headphones
Do sennheiser tr120 wireless headphone rechargeable batteries ever need changing
Yes All batteries are subject to failure and eventually need to be replaced, some last longer than others it's a manufacturing consistency problem. ...
Feb 27, 2015 | Sennheiser RS 120 Consumer Headphones
I have Sennheiser 120. Set it up right. One side or the other comes in clear. Never both sides at the same time.
I have a set as well but the batteries were weak and it was doing the same thing when they were new. Replaced with good batteries and that was the problem. if you try this and they still don't work then just return it for a replacement
May 17, 2014 | Sennheiser HDR 120 Consumer Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
No sound thru my Sennheiser RS 110 headphones!
check with the manufacturer's website . Perhaps they have technical support
Jun 01, 2009 | Sennheiser RS 110 Consumer Headphones
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Jan 10, 2008 | Sennheiser HDR 130 Consumer Headphones
460 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
