Have received 2 calls purporting to be from Telstra re hacked internet line and wanting me to log in so they could help numbers were 0911222095 and 0918501787. Are these genuine calls?
SOURCE: N70 Call Logs
just reset the phone it might solve your problem.
here's the code to reset *#7780#
peace!
SOURCE: Nokia N95 wont display Log
Resetting to factory settings will probably sort it out. But you might loose the data stored on the phone. You'll find the reset in the menu, tools, settings.
I'm assuming that you switch your phone off sometimes, if you don't, try a restart first.
SOURCE: Lexmark x215 printer/fax/scanner
I have an X215 also. It is not built to suit a duo line hence no fix is available.
SOURCE: LG Shine CU720 -cannot access the internet or mms-unlocked phone from Telstra
I have an Lg Shine CU720 and I can't unlock it. Can you help me please. I need an unlock code.
if MMS is blocked then the internet for sure will be locked they run off the same
