SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: motor has burning smell. belt and controller were
May I ask witch belt? Most treadmills have two belts, one to drive the gearing and one the patient walks/runs on. The tension and alignment are factors in the load on the motor. Too much tension on the belt the patient stands on will overload the motor. Alignment of both belts is a load factor. Eliminating the belts, tension, belt rollers, and control only power wiring and the motor is left. If the motor is the culprit call a local electric motor repair shop for testing and possible repair. Maybe cheaper than a new motor. : ) : )
SOURCE: My Life Fitness treadmill needs
if it is a classical model 9500/9500HR/9100/9100HR can take the card to a qualified technician mail, you must open the controller and change the following components: D4015L (2) 2N6507 (2) TIP110 (1) and in the latter case there to change the IRGBC40S.
if you treadmill is the Next Generation you should buy new and can find on sportsmith.com
