I have been looking and a web sight that states that the drives will start installing on there own yet it dose nothing can someone please tell me what im doing wrong
SOURCE: sony dcr-dvd201 unable to connect via usb to xp pro computer
I assume you put the camera into vcr mode after connecting the cable? Are you sure you've got the cable plugged in to the correct places both on the camera and on the PC? The camera won't register until it's turned on, and it may require play mode.
SOURCE: Cannot connect using LG internet cube software
how can we install the modem driver correctly please help.. confuuuuuuused
The_Wise23 - delete and try reinstalling your lg usb modem if that does not work call your provider and see if they can assist you more.
chinesebox - the best thing to do is uninstall all lg software and then reinstall it.
for all other users un-install then reinstall
I had the same problem but now i have found the solution for it. Its not the software its the phone. Go to your Phone Settings hit Connectivity and then Usb Connection select Data Service and now connect your phone to the pc and select connect in Mobilesync and it should work. After you are done using MOBILE SYNC you can simple go in settings once again and choose mass storage for any downloads!!!
SOURCE: I'm having trouble installing iTunes 8 to a PC
when you start the install just change the install to C:, then you my have to do that once more, something messed up the drives order. It could be what is called a virtual drive, that just means u are using an emulator, it's too long for me to explain but a hard drive is almost alwayd drive C, dont forget the:
