Question about Frigidaire Washing Machines
How do I remove a side panel from a Frigidaire top load model fws445rfs2?
    Top Expert:
  • Frigidaire Master
  • 55,370 Answers
May be a wrap-around cabinet
Posted on May 09, 2018
Anonymous
SOURCE:
Ian Greenland
  • 351 Answers
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Posted on Mar 21, 2008
D Clare
  • 116 Answers
SOURCE: frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Posted on Sep 20, 2008
JEFF SIEGEL
  • 311 Answers
SOURCE: what is the capacity of the top load frigidaire washer FWS445RFS2
Should be in the manual or advertising info. Go to frigidaire.com and you should be able to find it. Thanks, please leave feedback or contact me again for more info if you need it.
Posted on Nov 29, 2008
rich553
  • 44 Answers
SOURCE: Good afternoon! We have a Frigidaire top load
Joe, remove panel to get access to outside of outer tub. You will see a "bell" with a soft 3/8 clear line coming from it. That is your water pressure hose and it goes to a switch in the control panel. Remove one side from the bell housing, outer tub, and check for gookus. Clean out all obstructions. If there isn't any obstruction in the line, you need a new pressure switch up in control panel. There is a small chance that there is something on the inside of the outer tub which is obstucting air bell but I don't see this very often. Hope this helps,
Rich
Western Appliance Repair
Appliance Repair Nampa
Posted on Oct 09, 2010
briannz1
  • 15 Answers
SOURCE: I have top load washer,
this could be the main seal which would make this repair expensive, if it coming out the centre of rotor cap on the direct drive motor
Posted on Dec 21, 2010
How to replace lid switch on frigidaire top load washer
I believe same as Kenmore you have to remove the top panel, first remove the 2 plastic pc.s from the side panel, then u will see on each side a screw that needs to be removed, then lift panel up and out of way, u will see 2 gold clips near the center that need to be preyed or popped out, then the whole cabinet will come forward and out. look under it and u should see the door switch and a couple screws holding it to lid panel remove them as well, then unscrew the ground screw to the harness usually a green wire connected to the frame.
Feb 25, 2014 | Frigidaire CWS3600AS Top Load Washer
Pump dose not come on spin cyl fws445rfs2 top loader
Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 07, 2012 | Frigidaire GLWS1233A Top Load Washer
Frigidaire fws445rfs2 will not spin but agitates
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 24, 2011 | Washing Machines
How do you get the front panel off of a Frigidaire Washer Model ATF8000FS1 to get at the coin trap?
The 7000 model and probably yours too, does not have a small front panel at the bottom that comes off. You can't access it from the back. The four screws at the bottom of the full front panel come off-- then go to the back and take off the top. Remove the screws at the detergent/softener drawer, and take it out-- remove the screws on the control panel and it can lay on the top of the machine... you can then get at the top screws on the front control panel... remove them and before taking it completely off... remove the contacts in the right side of the door by removing the two stainless screws similar to the ones removed from the detergent drawer. You should be able now to pull the front panel to access the boot.. Be sure to pull out the coin trap fully and rinse everything out... when putting it back be sure all the clamps and brackets are replaced properly or it will leak.
Jan 08, 2011 | Frigidaire ATF6000ES Front Load Washer
I have top load washer, model #FWS445RFS2 that is leaking at the bottom where the motor mounts to the tub. Is this easily repaired?
Dec 21, 2010 | Frigidaire Washing Machines
Good afternoon! We have a Frigidaire top load washer, model # FWS445RFS2. The tub continuously fills with water and we must manually stop the washer and then turn the dial to spin & drain. It cannot...
Rich
Oct 09, 2010 | Frigidaire FWS833A Top Load Washer
Frigidaire GLWS1233A Top Load Washer is leaking from the bottom, there are no kinks in the hose, water is coming from the bottom.
there is a chance that the tub seal is broken. in orfer to check it you need to remove the front panel by taking the two screws out of the bottom the push the two clips in that are located about an inch in from either side of the washer the lid will pop up and then you can remove the front panel.
then start the washer again and look to see where the water is coming from
Sep 17, 2010 | Frigidaire GLWS1233A Top Load Washer
An old model Frigidaire top-load washer - the old "turn the dial, and pull out to start" type. Drum won't agitate - what, if anything, can I do?
Remove the front panel and inspect the drive belt. It is probably worn out and or stretched.
The Frigidaire style you have does not take overloading very well.
Also check the lid switch for continuity. It must be good for agitation to occur.
Nov 01, 2009 | Frigidaire FWS1339A Top Load Washer
What is the capacity of the top load frigidaire washer FWS445RFS2? And if possible, other specs. Thanks.
Nov 28, 2008 | Frigidaire Washing Machines
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
