Question about GE Home Security
How do i pair a ge wireless door chime 19247 button to its reciever?
  • GE Master
  • 4,331 Answers
Anonymous
SOURCE:
Anonymous
  • 638 Answers
SOURCE: wireless door bell
yes it is true uchange the place of the chime some were elsethats simple. do it. and try
Posted on Jun 11, 2008
Anonymous
SOURCE: door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Posted on Dec 16, 2008
Anonymous
  • 111 Answers
SOURCE: Ge wireless Batery Opereted chime 1601s
From what I have researched it is cheaper to purchase another unit. Here's a link I hope this helps.
http://www.smarthome.com/2042/2-Entry-Plug-In-Wireless-Chime-Wireless-Doorbell/p.aspx
Posted on Jul 02, 2009
tfelton3
  • 183 Answers
SOURCE: wireless door bell rings when no one there
most likely on the same frequency! They have a pretty good range on them, I'd go but a different brand!
Posted on Jan 07, 2010
John McPherson
  • 1212 Answers
SOURCE: Friedland Evo Wireless Door Chime and Push Problem
While this is a little bit of a stab, if you replace the batteries in both units, do it at the same time, If the batteries are known good ones, simply take them both out and let the units sit for about 5 minutes before you put them back in. Make sure the battery contacts are clean and devoid of corrosion. Put them back together without pressing the button. I assume it is of the newer "self learning" style. In which case, hold the ringer button down until the chiime goes off.
If it is one of the optical greeters, there would be a setup switch position that allows you to focus/align the reflector for the greeter. Usually it keeps chiming until the alignment is correct whereupon it shuts off when things are right. Then you reset the switch to normal. If no switch for set up at all- just follow the same procedure until it stops. You can usually "eyeball" them pretty close without effort.
Posted on Dec 31, 2011
GE wireless door 19216/ST-66
They pick up signals from taxis and tow trucks. One some you can change the channels. Unfortunately the problem of 'wireless'.
Jan 29, 2018 | GE Home Security
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
Oct 16, 2015 | Home Security
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
Program simon security system chimes
To turn the chime on for your door/window sensor on a Simon 3 panel push the "chime" button on the keypad. Hope that helps!
Oct 27, 2012 | GE Security Simon 3 Wireless Home Security...
I have a wireless SL-6151-RX-A door chime and it does not ring
Check that the dipswitches on the button and the reciever doorbell unit match. Also verify that your battery is not installed the wrong way.
Nov 15, 2009 | Desa International White Wireless Plug In...
Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Aug 31, 2009 | Desa International White Wireless Plug In...
Jul 02, 2009 | Computers & Internet
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
1,686 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
