Could a button be stuck on the remote, maybe the Menu button?
Testimonial: "no, it will do it even if you turn on tv at the tv and don't use the remote"
But if the remote has a stuck button and is pointed toward the TV, the stuck button would still send a signal. Either face the remote away from the TV or remove the batteries for the best test.
Also try unplugging the TV overnight and plug it in tomorrow. That might give it a chance to reset. If not, you may have a problem with the TV and need a technician to start replacing parts. Good luck.
Thank you. Will try that.
I have a tv it's keep going to the set up wizard
SOURCE: My Westinghouse LCD tv starts out fine, but after
Hello, with this model there are two thing you can do. One its the cheapest which could be causing the problem, this would be the LVDS cable, this cable runs from the top of the main board and in to the T-con board hidden under the main board. What tends to happen is that adhesive in the tape that holds that cable wears out with the heat and over time the connection comes loose, the way to fix this is to replace the tape with foil tape found at your local hardware store. The second thing that can cause this is the main board which you will need to purchase and can find out the price and availability by emailing [email protected]. Hope this information is useful, if you need information of how to repair the LVDS cable I have a sheet on how to do it including pictures. Please feel free to rate me if my help was useful.
SOURCE: After 1 -2 hours watching tv hear a pop and set
No,the effect will take longer and longer to turn on tv and dies all together later on.Power supply board have parts call capacitors,have problems.These capacitors parts on the power supply board are dying and have leaking gases.The board where the power a/c cord plug into it.That the power supply board.Searches the power supply board.U now basic eclectronic's,have tools and know basic slodering?These dying capaciitors parts are alway bulges up on it tops or puff up on it tops,must be replaced.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
