SOURCE: No Ice Cubes
Maybe water inlet tube is stopped up with ice so water is bypassing ice maker and dripping into bin.
Or is the water inlet valve on the back not shutting off.
Either way check water inlet valve. http://www.acmehowto.com/howto/appliance/refrigerator/check/inletvalve.php
SOURCE: ice from ice maker taste bad and can not find a water filter on it.
I would install a filter inline on the water filter I have one under the sink and on the ice maker
SOURCE: i turned off my ice maker with the switch on the
How did you know it is not on? A single cycle for an ice maker takes some time to complete. They don't have reset buttons. You just lower the arm to turn it on and raise the arm to turn it off. The cycle goes like this. The tray is filled with water then as the water freeze it reaches a temperature that which triggers a sensor. Then a heating element melts the bottom of the ice then the mechanism rotates and dump the ice. Cycle starts again. This single cycle can take a few hours to complete. If the cycle is interrupted by turning off the water, it could take a while because the ice maker will go through the cycle regardless.
SOURCE: My ice maker was not dumping ice from the tray. I
It sounds like the water inlet for your ice maker is now frozen. Blast a hair dryer around the waterinlet to the ice maker for 5-10 minutes, reconnect the ice-maker and you should hear the sweet sound of flowing water
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
