SOURCE: Kodak Carousel 600 Projector - mechanism stops with slide out
Open the back up and spray just a LITTLE bit of WD-40 into the cavity where the bit of spring emerges from the grease covered cam shaft. This will loosen up the grease that has dried up. It may take up to half an hour to work on the grease. If things are improved but not perfect, repeat. If any WD-40 spills out, mop it up with Q-tips and especially avoid the rubber belt.
Please do NOT advance things manually ans especially don't pry apart any of the plastic or metal cams on the cam shaft in an effort to correct the timing. You will put it out of waht and it will take a whack of time and/or an expert to get it back in whack!
SOURCE: we actually have a kodak 600 carousel projector
Given the age of your Carousel Slide Projector, my guess is there is a broken "link" in the slide change mechanism. This "link" is plastic, and connects the cycle solenoid to the slide change mechanism. Over time, the "link" gets brittle & breaks, giving the failure condition you describe. You should consult an Authorized Repair Dealer to see if they can still get parts for your projector, which was built between 1964 and 1972. Best of luck !!
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
SOURCE: kodak carousel 760h projector
Neither of the "trademarks" you mention were used by Kodak, so the lens must be a non-Kodak lens. First of all, remove the lens and look along its side - it should have a rectangular "rack" (dimensions of the "rack" are roughly 1/2 inch by 3 1/4 inches) with gear teeth that will connect with the corresponding gear (inside the projector) on the focus knob shaft. If the lens does not have this "rack", then you should try to find a lens that does. (One source for lenses is www.VineValleyImaging.com). Verify that the lens is on the focus knob shaft and does not appear to be damaged. If the gear on the focus shaft is damaged (or slipping) you will need to contact a Authorized Repair Dealer to see if parts are still available for your specific model. Let me know if you need anything else! Good Luck !! Jim
SOURCE: Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
