SOURCE: sound lost on digital lifestyles tv
Try unplugging it for a few and starting over, check your connections. If that does not help it is probably broken. This brings you to the bigger problem, It is no mystery why all of these new "no name" TV manufactures are so much cheaper than 1st tier products. Some of it is quality, but the biggest reason you spent a few to maybe several hundred less than the Sony, Toshiba, Samsung, Mitsubishi, etc. is after the purchase support. If your TV is broken chances are it is not getting fixed. There is no such thing as Digital Lifestyle replacement parts, service centers, service manuals, etc. If a company can build a TV then wash their hands of it they can sell it much cheaper. Name brand manufactures produce original replacement parts for years, they set up authorized service centers all over the country and they publish service info for their servicers. You might take it in somewhere for a look, sometimes it is something simple or basic electronic circuit failures that can be repaired with common generic components, but if you need something specific, it won't happen. You say it is "new" if it turns out broken and you can return it, do it, go smaller with a name brand or spend the extra few hundred bucks. Don't get me wrong name brands break too, the difference is they are repaired and you move on rather than throwing it away and buying again. People are discovering there is nothing more expensive than a cheap TV. Good Luck
SOURCE: Finepix J10
Hey bet10,
A brand new camera should not come with any images stored in the internal memory, and you should not be getting this message. It is true that if the internal memory is full and there is no memory card inserted the camera should not allow you to take any images since it has no where to store them. I would try formatting the internal memory by following the directions on page 84 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I will say that digital image files are usually rather large and your internal memory is rather small, and I would suggest investing in a memory card if you already haven't. I hope this helps!
http://www.fujifilmusa.com/shared/bin/J10_E.pdf
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: driver panasonic rr us395
go to the following link and download your driver
www.filecyb.org/files/panasonic-rr-us395-driver
SOURCE: car radio renault model 22dc278/62b
MODEL NO:22dc278/62b
tow487
rn 278f20283193
prod no:fd0302380283193
