SOURCE: Touchscreen stopped working
Some where else in this site it said to hold the menu and map button while powering it on. I did that and it fixed my touchscreen problem, however I did loose all data, but I have that saved on my PC.
SOURCE: brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
SOURCE: garmin 250w keeps resetting itself, GARMIN logo
Probably needs a new logic board at this point. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
SOURCE: my garmins locked or something...the
Try a reset
Resetting Your nüvi 205W. PLEASE READ ALL BEFORE TRYING.
Press and hold the RESET button on the bottom of the nüvi for several seconds.
Clearing User Data CAUTION:
This deletes all user-entered information.
1. Hold your finger on the lower-right corner of the nüvi screen while turning on the nüvi.
2. Keep your finger pressed until the pop-up window appears.
3. Touch Yes to clear all user data.
All original settings are restored.
Any items that you have saved are erased.
