Question about Datamax Office Equipment & Supplies
Our Datamax 4212 printer keeps pausing during a print job. It 1st prts 80 labels then stops for about 2 min then prts about 10 labels and repeats. What can be done to keep it printing continuously?
Anonymous
SOURCE:
ozztech
Paulo Rangel
  • 285 Answers
SOURCE: Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Posted on May 08, 2008
Dan Stolze
SOURCE: Pausing between labels
I have found that using the designer driver causes this problem. You may need to go back to the originma driver for that printer if this is the case for you.
Posted on Jun 05, 2008
Dave Busselle
  • 54 Answers
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Posted on Feb 25, 2009
bartech9
Roberto Martinez
  • 155 Answers
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Posted on Jun 10, 2009
mdgm
  • 89 Answers
SOURCE: Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Posted on Jul 17, 2009
I have a Datamax DMX I-4212 Barcode Printer. Computer operating system is Windows XP. I use a third party software package, to produce barcode labels. The company is Argos Software. The printer is set as a...
Welcome to FixYa.
It shows that the printer is not communicating properly with the computer.
Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.
Thak you for using FixYa.
Dec 23, 2011 | Datamax DMX-I-4212 Label Printer
I want price of print head datamax 1-4212- 203dpi
Looks like around $210
http://www.officelink-inc.com/ProductDetails.asp?ProductCode=OLK20218101&Click=90
Mar 14, 2011 | Datamax DMX-I-4212 Label Printer
Why wont my datamax 4208 printer read the same label format as the 4212
It will read and print the label format, but you need to download and choose a different driver for the other printer. Seagull Scientific makes the drivers for Datamax, so visit their site for the most recent versions. you will need to open your label format in your software, duplicate the label format and choose the new driver for the I-4212.
Sep 10, 2010 | Datamax DMX-I-4212 Label Printer
HELLO!! MY EQUIPMENT IS DATAMAX DMX-1-4212 AND TO THE MOMENT TO STAMP THE RIBON WRINKLES AND ORDERS THE IMPRESSION WITH STRIPES
poor tension on the rollers?
try pulling the ribbon during stamping, if this corrects it then you may need a tech to come and reseat some drive gears.
Jun 10, 2010 | Datamax DMX-I-4212 Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Datamax I4212 printer is dropping characters on large prints jobs from Easylabel. Any idea why?
If you are using serial port (COM1), problably your cable doesn't have flow control. You need a cable that use RTS,CTS and DSR. If you are using paralell port, make a change to serial port.
Nov 19, 2009 | Datamax DMX-I-4212 Label Printer
Datamax I-4208 ribbon loading
Follow the arrow symbols stamped on the ribbon spool assy
Sep 24, 2009 | Datamax DMX-I-4212 Label Printer
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Hope this helps you.
Nov 14, 2008 | Datamax DMX-I-4212 Label Printer
NEED MANUAL
Try this link:
Theres 2 programmer manuals. One is for version 10 softare, the other is for version 11 and higher.
Sep 10, 2008 | Datamax DMX-I-4212 Label Printer
115 people viewed this question
Top Datamax Office Equipment & Supplies Experts
rongg
Joseph Mueller
Joseph Mueller
Pierre Legault
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
