I have UK maps in my home computer in the UK can I download them to my 1515 tomtom
Yes, your GPS device can have more than one map ... assuming there's enough memory (RAM or SDCard) available on your device.
Just copy the map (from your home computer) to the GPS device (memory), then install the map using the activation code (for that map) on your device. After that is done, you'll be able to use the UK maps on the device (by switching map to the UK map, using the navigation software)
SOURCE: tomtom one maps
I just had this same problem. Quite strange. I have a Tomtom One New Edition and connected to a Vista Ultimate computer. Here is what I did to fix the problem I was having.
Exited out of the Tomtom HOME application. Went to "Computer" and right clicked the Tomtom drive (was M: for me, could be different for you) with the Red Icon. Selected properties and click on tools. From there I selected "Error-Checking" and only checked "Automatically scan and fix errors for me". It said it found a couple errors and corrected it. I then doubled clicked the icon in the bottom right portion of my screen which looks like a USB plug with a green check mark on it. I selected the drive and clicked stop. I disconnected the usb plug and then used a small tack on the bottom of the Tomtom unit to reset the device. After that, I turned the unit on and all was fine and I could clearly see that an update was applied.
Good luck! They really should have a support bulletin for this as this is clearly a common issue.
SOURCE: TomTom Home
I had a similar problem when trying to update my dad’s old
TomTom Go300. I bought a new map and downloaded TomTom Home 2 (as
instructed on the website) but found that the Go300 was recognised by the computer it wasn't recognised by TomTom's own Home 2 software.
To cut a long story short I uninstalled Home 2 and downloaded Home 1 (from http://www.tomtom.com/plus/service.php?ID=17 Home 1 is the one on the right, listed as being the version of Home you use for Navigator 6).
Then when I switched the Go300 on it was recognised by Home1 - although the new map I had bought wasn't listed as being available for download.
However, I updated the Go300 with the available listed free updates, then switched it off.
Downloaded Home 2 again and switched the Go300 on - this time it was recognised by the computer and the new map I had bought was available to download.
So far so good - the only problem was the the postcode search facility was not the same as it had been - I could now only search the first 4 digits of the postcode. There is a fix for this on the tomtom website:
http://www.tomtom.com/support/index.php?Language=1&query=postcode&FID=9852
which I followed and which worked.
Hope this may be of some use to someone! It took me hours to figure it all out. But it's up and running now.
Redd
I read and read and re-read the TomTom website looking for any info
that would help but came up with nothing. A few hours later and the air
thick with torrents of language I didn’t think I was capable of I
discovered that I needed to download Home1 first and let the Go300
connect to the computer via Home1 before it would be recognisable by
Home2. Okay…
On the website, though, Home1 is listed as being the version you use
if you have TomTom Navigator 6. It’s not even called ‘Home 1′.
Confusing eh? Anyway, I downloaded that and from there found that I
could get my new map onto my Go300. Once the map and other updates were
installed and I had switched the thing off I then found that Home2
recognised it at last.
That had to be one of the most ridiculously long-winded things I’ve
had to do on a computer, mainly because TomTom’s confusing advice on
their website made the whole process so damn difficult. Perhaps they
hoped I’d give up and buy a new one? Tsk.
Redd
SOURCE: tomtom computer voice
Hi, Yes . You can get many free voices on the internet . For funny or famous people try :
http://www.ozpoi.com/TomTom_Voices.html
or try a look here :
http://gps-data-team.com/pda-gps-navigation/links/index.php
Good luck
SOURCE: no maps found??
The problem is caused by a version mismatch between the Application version and the Map Version. They must both be the same. For example, if the TomTom has not had the application updated, but you updated the maps, the TomTom will not know how to read the file.
Make sure that if you are trying to use a version 815 map, that you are using a version 8.XXX application too. I had to upload two application version changes before I could read the new USA maps.
SOURCE: Upload latest western europe map v7.20 to TOMTOM 700 not possible
I have managed to solve the problem of loading a new map on my Go700 using a Mac. I discovered that Tomtom is incompatible with the Leopad operaying system, despite the protestations of the idiots at Tomtom ,so I reverted to an older Mac using Tiger.
Taking the instructions given to crinold, I tried to erase the disc on the 700 using home 1.5 - and it didn't work. So I went to disc utilities, highlighted and erased the Tomtom disc, and opened home 2,5. After being refused entry several times, like being told to load an already loaded device, I persevered, and managed, slowly, to add the map I had bought for 78 euros. T]One point oif interes is that when I bought the map, they site stated it would cost 63 pounds sterling, but switched it to euros when the invoice arrived. at a rate very favourable to Tomtom - funny, that.
This is sharp practice,probably illegal in many countries,, but, to be honest, dealing with the mysterious Tomtom company is so frustrating, that I don't have the time or inclination to fight them for the money they cheated from me.
How they survive with such an awful product and extremely bad after sales service is hard to understand - perhaps they won't ... we live in hope.
