SOURCE: hi,i would like to know how to set the traulsen
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
Part 257 on this diagram is your defrost timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=TFX22JABAAA&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-B-SERIES&diagramPageId=00005&componentDescription=FRESH%20FOOD%20SECTION&documentId=E2134230&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: Our Traulsen Freezer will not hold the cooling
Have someone out to do a nitrogen leak check on it. Sounds like a leak needs to be found and fixed. Hard to find leaks can be spotted by adding UV dye to the system.
SOURCE: Hi I have a traulsen RHT 132 EUT FHS inside the
sounds like a clogged drain pan drain. Could be the drain line heater is not working so when it goes into defrost, the water can not drain as the drain line is frozen up and acts as a restriction/ clog. could also be some good old fashion junk/ dust.
Check it out.
SOURCE: i need a wiring diagram
the only way to get a diagram is to contact traulsen and give them the model and serial. they seem to not be very forth comming with those.
1-800-825-8220.
SOURCE: traulsen commercial fridge will not cool
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
