The hazard switch contacts must be stuck together causing constantly flashing signalling .
Robert
I have tried disconetct the hazard switch but have the same error . When i pres the right or left flash sometimes it stopes but starts again without touching nothing . Is ti poslible that dash board is something wrong .
A wire or wires may be shorting causing this issue . I am looking for a schematic but have yet to locate one .
Bad switch it is stuck on
Any help from someone pleasee
Go dealer and order a new switch in the meantime disconnect the old one
I have disconected but no results
SOURCE: electrical problem
Find the ground wire on one of the lights and add another ground wire to a good clean metal surface and see if that fixes the problem. It defently sounds like a ground problem at one of the lights.
SOURCE: Indicator lights no longer blink its one solid light
Im Not Totaly Sure But Most other Makes & Modles Ues 2 Seperate Signal FLASHER Units
Your Owners Manual Should Show this As Turn Signal "FLASHER" Located At or Near Fuse / Relay Box This is ASUMING you have Checked The Fuses and Relays
SOURCE: 2005 Silverado - Hazard lamps come on when I use right turn signa
It is your flasher module. It is on the backside of the fuse box under the dash. You need to remove the panel below the steering wheel, above the peddles. The replacement part number is 10383321. Once you have the panel off it just pulls out and replace it with the new one. I got one on ebay for about
$30 shipped.
SOURCE: 2005 magnum esp/bas and engine light on
you need to see what the eng lite for if there is a trans codes usually the pcm wont let the speed go over 40 stays in safe mode untill you fix the problem or change the sensor,for the esp you need to chage the esp sensor and recalibrate by the dealer
SOURCE: 2005 Dodge Durango. Some times left and right
Sound like the turn signal switch is bad,also check the harness if you have an aftemarket tow hitch.
Anybody help !!!
