Samsung Smart TV hidden secret menu allows you to do a factory reset and also connect some Bluetooth devices which you were unable to do before. Be careful while fiddling with these options as I cannot take any guarantee if you spoil the TV settings. The Samsung Smart TV I used in the video is Samsung F4500. The secret menu will not open with a smart remote. You may buy or borrow the original normal rectangular Samsung remote to access the secret menu but I am not so sure that will work.
Here are all methods to access the secret menu of different Samsung smart TV:
Method 1
Put the TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV on standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Method 7 for Smart TV RU7100, NU7090 Series 7 (suggested by viewer Caleb Harch)
<p><span>Here are some codes for samsung cell phone that can help you out in
problem</span><span></span><br />
<p><span>*#06# Displays your IMEI </span><span></span><br />
<p><span>*#78# Test touch sensitivity</span><span></span><br />
<p><span>*#03# Displays a Unique number </span><span></span><br />
<p><span>*#7465625# Phone lock status </span><span></span><br />
<p><span>*#232337# Bluetooth MAC Address </span><span></span><br />
<p><span>*#1234# Software Version running on your phone. </span><span></span><br />
<p><span>*#2222# Hardware Version of your phone. </span><span></span><br />
<p><span>*#0228# Displays battery information. </span><span></span><br />
<p><span>*#0289# Melody test </span><span></span><br />
<p><span>*#0782# Displays the real time clock of your phone. </span><span></span><br />
<p><span>*2767*2878# Displays a Service menu</span><span></span><br />
<p><span>*2767*3855# , *2767*688#This code performs a full reset. </span><span></span><br />
<p><span>*#0842# Vibration test </span><span></span><br />
<p><span>*#0*# Speaker & LCD display Tests samsung security </span><span></span>
<span>Every phone comes equipped with a secret codes where technician can easily access its internal settings and run testing modules. These codes or secret access are usually not specified in the phone manual that comes with it. Here are a few secret codes that all Android mobile phones users should know, especially samsung users.</span>
<span><br /></span>
<span><span>
<p><b>Accessing Phone Info</b><br />To access the internal Phone Information, Battery Information and History, as well as Usage Statistics, open up your dialer and press *#*#4636#*#*. From here, you can find out additional phone information and make the necessary adjustment (only if you know what to change, otherwise, don't simply amend these settings).<br />
<p><b>Reset All Data</b><br />To reset all phone data, press *#*#7780#*#* from your dialer.<br />
<p><b>Format phone</b><br />To format the entire phone, press *2767*3855#<br />
<p><b>Camera Info</b><br />To know more about your android phone camera firmware, press *#*#34971539#*#* from the dialer.<br />
<p><b>Shutdown / Button Action</b><br />Pressing *#*#7594#*#* will allow you to access the Shutdown setting.<br />
<p><b> (GPS)</b><br />Go to the phone dialer and press *#*#1472365#*#* and you will have access into LbsTestMode menu. From here, you may test and amend some default GPS configurations.<br /></span></span>
the usual process is to,turn phone off... hold the "volume up " button and the "home button" together, keep holding the buttons down,then power on phone but keep the buttons pressed until you see the android secret menu ( if your phone boots up then try again holding both buttons )
so, there are your secret codes! gprs menu=*#4777*8665# java test menu=*#52828378# hard reset(remember to back up all your data before hard reset as it will delete entire things of your mobile, even virus from phone memory)=*#2767*3855# that is all for your phone. best of luck!
Samsung Secret Codes Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: *#9998*324# - *#8999*324# LCD kontrast: *#9998*523# Vibration test: *#9998*842# - *#8999*842# Alarm beeper - Ringtone test : *#9998*289# - *#8999*289# Smiley: *#9125# Software version: *#0837# Display contrast: *#0523# - *#8999*523# Battery info: *#0228# or *#8999*228# Display storage capacity: *#8999*636# Display SIM card information: *#8999*778# Show date and alarm clock: *#8999*782# The display during warning: *#8999*786# Samsung hardware version: *#8999*837# Show network information: *#8999*638# Display received channel number and received intensity: *#8999*9266# *#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together *#8999*8378# Test Menu *#4777*8665# GPSR Tool *#8999*523# LCD Brightness *#8999*377# Error LOG Menu *#8999*327# EEP Menu *#8999*667# Debug Mode *#92782# PhoneModel (Wap) #*5737425# JAVA Mode *#2255# Call List *#232337# Bluetooth MAC Adress *#5282837# Java Version Type in *#0000# on a Samsung A300 to reset the language Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710) Samsung E700 type *#2255# to show secret call log (not tested) Samsung A300, A800 phone unlock enter this *2767*637# Samsung V200, S100, S300 phone unlock : *2767*782257378#
Display test
