Patching is always temporary i would contact stihl and get a replacement
Welcome to STIHL com STIHL http://www.stihl.com/ go to your area and click on it the tank is right there.
SOURCE: Fuel bubble cut on Stihl trimmer. ,how to start
yes you can temporary fix with puting some mastic sealer over the bubble and leave for a few hours.
SOURCE: stihl line trimmer starts but won't stay running
check to make sure your kill switch is not shorting and you have the right gap from the coil to the flywheel also if the flywheel sheer pin is damaged in the least this will cause a multitude of problems... it is the timing pin and must be in good shape not damaged or sheered ..any way reply to [email protected] and i will try to help you through this.... DALE good luck and will wait for reply..
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
SOURCE: leaking fuel tank stihl fs76
no seals just the tube seals itself to the hole in the tank for it
SOURCE: need a diagram for fuel line placement on Stihl FS36 line trimmer
Hi Lee Miller
Hope this is what you need
Please take time to rate me
Bud
