Question about Sansui Televison & Video
I have a sansui tv le dije model SMX4219 and it is locked by PIN number, I can’t get in hdmi sources or any, please help me. When I try to make a factory reset it appears again. Please. Help.
6ya staff
SOURCE:
Anonymous
SOURCE: Child Lock Problem
Press and hold the TV/AV button and then press the red on/off button, the TV screen will become black, and any buttons on the main unit or the remote control become inoperative. If you want to switch on the TV, press and hold the TV/AV button and then press the ON/OFF button again, the TV will return to the normal TV reception
Posted on Jan 01, 2008
Anonymous
  • 78 Answers
SOURCE: Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
Posted on May 05, 2008
Anonymous
what is the cost of picture tube for model SV 2102
Posted on Sep 14, 2008
Anonymous
SOURCE: 2001 Sharp TV MODEL NUMBER 27N-S300
i have sharp tv.model ac/ca.my wife went bought me a innovage jumbo universal remote.it was missing the instructions and codes for this tv.can you help?thanks curt
Posted on Sep 25, 2008
Anonymous
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
My TCL TV is stuck on HDMI
change to tv air then channel search
Sep 10, 2018 | Televison & Video
How do i fix no signal problem and no vedio problem sansui 32
change source to AV or HDMI or RGB or Component or USB and try
Dec 18, 2014 | Sansui HDLCD3210 32 in. LCD TV
Tv changing channels on its own
What tv ? You tryed factory reset ??
Jan 03, 2014 | Sansui Televison & Video
Wharfedale 21in tv blue screen with the word key in top corner with 3 dashes please help
You have accidentally activated the system lock or parental lock. This usually happens when 2 buttons are pressed on the remote simultaneously.
You will need to enter a PIN number using the numerical keys on your remote. If you have set a PIN number for this TV you will need to enter this. If not, you will need to enter the manufacturer's default PIN number. This is usually a simple combination such as 000, 111, 222, 123, etc,
I can't tell you the exact PIN number without knowing the model number of the TV. Please try the simple number combinations shown above and post back with the model number if you need further assistance. The model number can usually be found on a sticker on the rear of the TV.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
Phillips flat panel hdmi locked. all other inputs are good.
got to manufacturer website find your model tv download manual from there
Sep 10, 2009 | Televison & Video
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Oct 18, 2008 | Sansui HDLCD-2600 26 in. LCD Television
HELP ME PLEASE............
You need to be more specific with the model number. Most Sansui TVs have model numbers like "SAN2701" plus a version letter like "Version A"
Additionally, procedures for removing the Child Lock, Panel Lock and TV Lock are in the users manual.
In some models, for the V-Chip, the original code is 000000, if you want to clear the code, please press the keys VOL + and VOL - on the front panel at the same time.The password of the TV's V-Chip Set up or Movie V-Chip Set up may be changed at any time. Press UP or DOWN to input the password,then press to select OK or Cancel. Press menu to confirm your input.
Hope this be of initial help/idea. Pls post back as to the exact model and version of your Sansui TV, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 31, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Sansui SV21276M. child lock on
Sansui Televisions in the United States are marketing and distributed by Orion Sales, Inc.
You can download owners manuals for Sansui TV's from their website at:
http://www.orionsalesinc.com
If you don't see your model listed there, do a search for the model number.
Mar 30, 2008 | Sansui DTV2760 27" TV
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Feb 29, 2008 | Sansui DTV2760 27" TV
Televison & Video Logo
21 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
