SOURCE: Lr code on display
it is a problem with the motor .this is confirmed.
Issue Washer stops in mid-cycle and/or flashes a code.
Warranty Standard product manufacturing warranty applies.
Action The motor drive system experienced a momentary loss of neutral feed from the power cord to the
Motor Control Board. The neutral line for the Motor Control Board passes across the water valve
solenoids. Neutral to the motor drive system can be momentarily lost If there is poor crimping of any
of the wire terminals in this circuit. This situation could result in a misdiagnosis and unnecessary
replacement of the Motor or Motor Controller Board.
Current Neptune front load washers will indicate a false locked rotor signal to the Machine Control
Board. Washers with a LED display will flash code “LR” in the display. LCD washers will display
“Locked Rotor.” The earlier built front loaders will not display a code, but simply shut down in midcycle
or will not start.
Pull each terminal of the white wire harness connected to each water valve solenoid and verify the
wire is properly stripped and crimped to the metal terminal connector of the wire harness. Make sure
the wires fit snug on the terminals of the water valve solenoids.
A product improvement has been made to the following models. The neutral wire is routed across
the pump only, and now by passes the water valve solenoids.
MAH55FLBWQ/W ..................... Series 12
MAH5500AWQ/W ..................... Series A7
MAH6500AWQ/W ..................... Series 33
MAH7500AWQ/W ..................... Series A6
SOURCE: THE FAULT CODE IS F9 ON A FAGOR DISHWASHER
Problem with distributor motor (or alternative motor). Motor locked, or sensor not detecting its rotation
SOURCE: Programmes for Fagor Select FU-1047
Sadly I don't have the answer, I have the same predicament as you! I don't suppose you have had any luck finding one have you?
SOURCE: Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
Ich habe die Waschmaschine FAGOR FE-1158 schon 7 Jare.Jetzt wenn voll beladen bei wasche stoppen und schlecht Wasser komt.
Ich bedanke vorher!
Mfg
30655 Hannover
SOURCE: My washing machine now reads lr and wont spin or
The lr fault code simply means Locked Rotor.This indicates that the main motor is not being detected as running by the control board in the console.This could be a wiring problem between the motor control board in the right hand base area and the main control board up top.Itmost likely is a failed motor control board or drive motor.
