Yellow--battery +
red--accessory
black-ground
blue-antenna
blue/white-remote
lightgreen-praking brake
white==left front spk- +
white/black left front -
gray-right front-+
gray/white right front-
green=left rear- +
green/black left rear -
purple= right rear +
purple/white rear-
brown-mute{if equip}
orange/black -illumination
orange- dimmer
purple/white- reverse camera input
SOURCE: kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
SOURCE: wiring diagram for a kenwood KDC MP232
Aftermarket cd players are all universal and have the same colors. You need to go to your local car audio store such as walmart, bestbuy, ect and buy a wire harness adapter. Then all the wires are color coordinated to make it easy, just wire colored wires together and plug in. If I have helped please leave positive feedback. Thanks
SOURCE: need to know what the wiring diagram for kdc-x789
well if you mean how to wire it up to ur car buy a radio adapter from best buy and color match all wires
SOURCE: Kenwood kdc-148 is in protect
A car audio component like an amplifier (or in this case a headunit) is most likely to go into protection mode when there is a short in one of the speaker outputs-- in other words, if the + and - ends of one of the speaker leads are touching, this can cause damage to the internal amplifier of the unit. Some units will respond by putting the amplifier into "protection" mode, so that it does not damage itself. Check connections on the back of your unit, or take it back to the shop that installed it.
