Cable modem router
SOURCE: Hooking ethernet to broadband router and cable modem
Hi Sherry,
The cable modem needs to be connected to the router to share Internet. The cable modem goes to the port labelled Internet or sometimes it is also labelled as WAN.
If you need further help, provide details such as the model number of the router and your Internet service provider.
SOURCE: Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
SOURCE: Router will not connect to internet
You will need to assign a different ip address to the modem - Iam assuming that both the router & modem are using the same ipaddress 192.168.1.1? If that is the case, then assign 192.168.1.2 tothe modem.
SOURCE: smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
SOURCE: I have a belkin vision
Can you clarify the problem?
Consdier first that both devices are NAT firewalls and your ISP probably only allows one address. So you would need to put one behind the other. This may not work like you plan. PCs behind the second will not be seen on the LAN by PCs on the first.
The N1 is a very good router. Consider relocting it to a more central location.
Another trick is to locate it near a central wall if it is block. By adding 1 remote antenna and drilling through that wall witha short antenna cable you can get much better coverage on the other side.
It could also be an ethernet problm 1. Power down SMC, plug WAN of SMC to LAN of router and power up SMC. If both devices show link lights and activity the hardware is OK. If not you need a "crossover" cable.
Hope that helps.
