SOURCE: wireless internet access
A wireless 802.11b LAN adapter is included in you tablet, activate it thru Control Panel / Wireless. Unfortunately this is the first generation standard and as such is extremely slow, has very limited range and is no longer supported by a lot of the newer generation devices/hotpoints.
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: I don't have internet connection on my my new asus tablet
Read and look at the diagrams on the following link. It should help you a lot.
Read this:
http://www.wikihow.com/Find-Your-WEP-Code
SOURCE: I have the digiland tablet dl700d(c) and I can't
Yes, Mike is right...MAC address do not change...maybe its the IP address...but then most of us including me have a dynamic Ip which keeps changing...but I do not have any problem in connecting through WiFi. Try switching OFF and ON the modem or upgrade to latest version...if nothing works...you can also opt for a static IP from the ISP.You can check in for the current IP in IP-details.com
