Not much you can check as it is a shorting problem
could be a start/run capacitor failure ore a compressor failure
call in a technician for a proper diagnosis
Testimonial: "Thank you for your time and advice"
Break is tripping due to over amperage rating of that breaker. Be sure you have the correct amperage rated for that piece of equipment. Need some additional info. Does it run for a while then trip? Does it trip almost immediately when turned on/plugged in?
SOURCE: fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
SOURCE: A M-G20010 keeps freezing coil every sevral weeks.
make sure doors close and seal all the way. are the doors being open constantly and in a high humidity area?
Is the set temp too low? How many defrost per 24 hours. Should be 4 and about 20 minutes each cycle.
Start there.
Hope this helps and let me know if I can be of any more help.
SOURCE: need access code for traulsen g20010
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20G-Manual%20(3-09).pdf
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20Rev%201004.PDF
Try this web site. It has 2 different manuals for your unit.
Let me know if I can be of any further help.
SOURCE: traulsen commercial fridge will not cool
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
SOURCE: I have the Traulsen G20010
Try to acces these sites as it has manuals for temperature controls. If you can not access this, let me know and I will try to email them to you.
