SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
SOURCE: Paper drawer is stuck open
Please pull out the tray.
Check if the rear end fence is out of place.
If so, please remove the metal plate with the spring, remove the gear in the middle of the tray (below the metal plate) and reposition correctly in its place the rear and front end fences.
Then try closing the tray.
Good luck and please rate me, thanks.
SOURCE: Unable to close the bottom oven drawer (Kenmore)
Pull the unit away from the wall and in most cases you can reach in the oven pan from then rear. If not.....pull the unit away from the wall and then lift the front about 3 inches away from the floor and let if drop....thus shifting the items in the drawer....If I can help further, I am here
Eric Campion
SOURCE: cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
SOURCE: NAD C521 CD Player
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
