Toby Juster Posted on May 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I raise a number to the power of a fraction my Casio calculator shows a decimal answer, what setting will put it in surd forms instead?
I used to get an answer as a surd, however reset my calculator. I have a fx-991ES PLUS.
kinestark
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 25, 2020
kinestark
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
502
Points
38
Great Post. Thanks for sharing this post.https://www.techappszone.com/2020/01/viva-video-for-pc-windows.html
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Jul 03, 2018
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4673362
Points
21595
Press the Shift/Mode key and set the Input/Output to MathIO.
Even that will not guarantee that the display will be in root form. Only square roots are possible.
4 Related Answers
  • 102366 Answers
  • Posted on Aug 04, 2012
SOURCE: my casio calculator is giving answers always in fraction form. I need to get the answers in decimal form (my calculator is fx-991ES)
To convert a single answer from symbolic to decimal, press the S--D key (just above the DEL key). To have all answers come out in decimal format, press SHIFT MODE 2 to switch to the LineIO mode.
  • 102366 Answers
  • Posted on Jan 01, 2014
SOURCE: I have a Casio fx 991ES and I'd like to have my
Select the Math input/output mode by pressing SHIFT [SETUP] 1.
[SETUP] is the shifted function of the MODE key, located just right of the round cursor pad.
julieazev80490
Abigail99
  • 4 Answers
  • Posted on May 18, 2017
SOURCE: on my casio fx-82au plus calculator it won't
the emulator and also kind 'VivaVideo' right into the search bar. VivaVideo Download You could download the app from the Google Play Store.
k24674
  • 8093 Answers
  • Posted on May 28, 2018
SOURCE: When I raise a number to the power of a fraction my Casio calculator shows a decimal answer, what setting will put it in surd forms instead?
Change the output display to MathIO. You may be able to display square roots only: so no cube roots, nor fourth...
1helpful
CASIO fx-9750GIII: Convert decimal answers to complex fractions?
to save time, I would suggest switching calculators and also recommend using an online scientific calculator to reach your goal. If the manual for your device is bad, you can look into getting a new calculator. Thank you.
1helpful
When I raise numbers to fractional Powers on my Casio calculator It gives it back in decimal form. How do i switch it to give answers as a surd?
4answers
On my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
Hi there, I have a Casio fx-991ES, and my calculator doesn't seem to be converting decimals in surd form... i.e. 0.3354101966 was the last number I typed in that didn't work... That, in surd...
The calculator can't identify that this is a surd unless you input it as a surd, ie as 3/(4*sqrt(5))= when it will then show the equivalent form 3*sqrt(5)/20 (obtained by multiplying top and bottom by sqrt(5)) and you can swap between the two forms using the S<>D button. Even adding the next 4 decimal places (hidden) won't allow the calculator to identify the underlying surd as this is simply too complcated a calculation.
7helpful
8helpful
How do I have my casio 115 es give answers as decimals instead of fractions?
To convert a single value to/from fractions, press the S<>D key.
To get all answers in decimal form, press SHIFT [MODE] 2 to select LineIO mode.
3helpful
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
1helpful
Casio fx-300ES Default answer readout?
Generally, MathIO gives results in fractions or radicals. But sometimes it does not. I tried multiplying or dividing fractions or radicals by integer numbers, and once in while I got a decimal result and was unable to cast it into a fraction or a radical. I was not able to find the pattern.
In lineIO you only get decimal results.
What can one tell you that you cannot determine for yourself? If you appreciate the functionalities of the MathIO, it seems like an insignificant price to pay to press ONE button to switch between displays. It needs to be done ONLY once, for the last result one wants to record.
Your calculator, Your rules. But sometimes one cannot eat the cake and have it too.
1helpful
2answers
Reset calcuator
try this, press shift mode, then line 10. It will make it permanent. the answer will always be in decimals. if you are using a casio with ES models.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
