Stevej9_98
SOURCE:need instructions for Wharfdale ccr1cd micro clock alarm
Press the STOP/CLOCK button for about 3 seconds till the hour number flashes
use the forward and reverse buttons to set the time on the hour
press the stop/clock button again to move on to minutes numbers
use the forward and reverse buttons to set minutes
Press the stop/clock button again to complete process
Posted on Mar 28, 2010
1Answer
Ccr1cd keeps turning off my yamaha receiver rx-v480 keeps turning off when i turn it on
check your speakers cables, connections. check for possible cable short. If seem ok, remove all speakers, turn the unit on and see if still turning off. if it does then you have a trouble in your power amplifier, defective output sectiuon. could be your power and driver transistors. possible dirty or corroded system control board. try cleaning.
SOURCE: need instructions for Wharfdale ccr1cd micro clock alarm
