Acer Aspire One  PC Notebook Logo
A
Anonymous Posted on May 29, 2018
When I turn it on a msg comes up with a blue rectangular border/bubble with white writing inside-Harddisk Security then just below that msg is SATA Port O TOSHIBA MK3265GSX Lock
Jessica Michael
Level 3:
Master:
  • Acer Master 459 Answers
  • Posted on Sep 19, 2018
Jessica Michael
Acer Master
Level 3:
Master:
Answers
459
Questions
Helped
305502
Points
1452
The error is generated when you enter the wrong HDD passwords multiple times. This requires the password to be reset. The steps below should help you unlock the screen.
1. Select the Enter Unlock Password option on the screen.
2. The laptop generates an Encode Key for unlocking utilities.
3. Type 'Unlock HP ' on the screen to execute the UnlockHD.EXE file to create the unlock code in DOS mode.
4. (for example UnlockHD 12365468)
5. The command generates a password. Unlock the HDD by typing the password in the Enter Unlock Password Key box. To Get instant support Call Our Toll-Free 1-866-293-9220
Larry Ng
Level 3:
Top Expert:
  • Acer Master 14,606 Answers
  • Posted on Sep 16, 2018
Larry Ng
Acer Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3279994
Points
66651
Hopless, this is.
bitlocker or hdd lockers, hdd encryption was turned on
did you do that or the person sold it used to you did that
if yes, other person only they can unlock that.
or buy new HDD (SSD ,10x better) and start fresh,
buy and OS, install it and run , w7 up, or Linux.
4 Related Answers
Anonymous
  • 236 Answers
  • Posted on Sep 24, 2009
SOURCE: When I turn my computer on I can not get passed a
I think you should try to remove your motherboard battery. After removing the battery you will be able to access your computer. Please try this.
Anonymous
  • 61 Answers
  • Posted on May 17, 2011
SOURCE: My daughter's Aspire One is
This password is a BIOS password and to reset it you'll need to go into BIOS and do it manually.
If the password comes up before any other loading screens then we'll need to flush the BIOS password cache, but hopefully we can solve everything by going into BIOS.
To enter BIOS hit the F2 key repeatedly as the computer boots up. You should enter BIOS after the first loading screen by Acer. If this does not send you into BIOS, try the DEL and F1 keys. You might also need to hold the F2 and DEL keys together. Once in BIOS find where you can set the password and reset it or enter a blank password as your new password.
If you can't access BIOS or are prompted for a password once you enter BIOS, try the following methods to flush the BIOS password cache:
1. Contact Acer support and ask if they have a backdoor BIOS password that they will allow you to use.
2. Send your laptop to Acer to have them reset the password manually, although this takes an undisclosed amount of time and I believe they will make you pay about $100.
3. If you don't want to pay Acer, open your laptop and locate the motherboard. On the motherboard there is a CMOS battery, if you don't know where this is use your PC manual. Remove the battery for an hour and then place it back on the motherboard. This should reset the password. After this turn on your computer and continuously hit F2, or whatever key you find opens BIOS, while the computer boots. This will reset all your BIOS settings so it may take a few minutes to open. After it is open, just exit BIOS and everything should be working properly.
Thanks for using FixYa and good luck!
mike
  • 114 Answers
  • Posted on Apr 24, 2013
SOURCE: border
go into tools, border, select none
kjanx
kj henriksen
  • 194 Answers
  • Posted on Aug 02, 2017
SOURCE: i have a lenovo lap top i turned on my laptop it it has a blue box that says harddisk security SATA PORT 0 WDC WD3200BEVT-24A23LOCK
that may be a virus/.
shut the computer off cold with power button, wait 20 seconds and restart it.
something has locked the hardrive
I have a dell inspiron 15R that has a blue screen telling me that its harddisk security and then it says Sata port o wdc wd10jpvx-75jc3t0lock? help? How to fix this??
The hard drive has been locked in the BIOS. If you cannot get into the bios with a password you can contact Dell for a code to unlock the BIOS and drive ... Here is a link that might help.
https://www.dell.com/community/Windows-General/Harddisk-Security-Sata-Disk-0-Lock-on-hard-drive/m-p/4429575
I have a lenovo lap top i turned on my laptop it it has a blue box that says harddisk security SATA PORT 0 WDC WD3200BEVT-24A23LOCK
Acer Laptop, hard disk security locked?
It seems that drive lock for this drive is enabled from BIOS. Is BIOS also password protected? Drivelock can be removed from there.
Recently changed the power supply. There is no video output. Where can I download the motherboard schematic?
Right here at HP Support,
1) Motherboard Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00361570&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459491
Scroll the page down to the top view illustration, and photo.
A) The motherboard uses a 24-pin ATX main power cable.
In the illustration the connector on the motherboard is on the right side.
It is an empty rectangular box with ATX Power Connector in it.
On the motherboard photo it is the rectangular white connector with two rows of 10 socket holes, and is to the bottom right of ram memory slot 2.
Another example of a 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Ensure that the 24-pin ATX main power cable's connector, is locked into place on the motherboard's connector. The lock tab on the main power cable must be hooked over the tab on the motherboard connector. This ensures that the main power cable is in all the way.
B) The motherboard uses a 4-pin ATX +12 Volt power cable.
The connector on the motherboard is a white square connector, with 4 socket holes.
In the illustration it is to the bottom left corner of the Processor socket (LGA 775), and has ATX12V underneath it. This power cable's connector also has a lock tab.
Another example of a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power TO the motherboard, that's it.
Power FROM the motherboard:
C) System Fan, and CPU (Processor) Fan.
Abbreviated as SYS_FAN, and CPU_FAN to the bottom left of the ATX12V connector.
(4-pin ATX +12 Volt connector on the motherboard)
The System Fan is the computer case fan.
CPU Fan is the Processor fan.
D) The four SATA headers on the bottom right in the photo, (Blue, Orange, Black, and White), are for the SATA data cables.
They connect to a SATA harddrive, or SATA optical drive. (CD/DVD drive)
(They are an L shaped connector inside, with 7 pins inside)
Power for these SATA devices comes from the Power Supply.
The Power Supply has SATA power cables.
Example of an average SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
(L shaped connector with 15 pins inside. The longer connector between a SATA data cable, and a SATA power cable )
Did you forget which SATA data cable plugs into where, on the motherboard?
Don't sweat it.
The beauty of SATA is that you can plug the harddrive's SATA data cable into ANY of the SATA headers (Connectors) on the motherboard, and BIOS will find it.
Same with a SATA optical drive, or any SATA device, for that matter.
IF, your SATA harddrive has a place on the back for BOTH, a SATA power cable, and a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
Using both will eventually burn out the SATA harddrive!
Example of a 4-pin standard Peripheral power cable, (Misnomered as 'Molex'),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
From there the main optical drive, (CD/DVD drive), has to have the audio cable plugged into the audio connector on the motherboard.
(Plus the power cable, and data cable, of course)
In the illustration this is the header down in the very far left corner, and located towards the bottom edge.
It has CD_IN marked underneath it.
In the photo it is the Black rectangular connector in the very far left corner.
If you didn't connect the 4-pin +12 Volt power cable, your Processor isn't getting any power.
No Processor operating, No computer.
No Signal on monitor.
(No video signal)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dear sir i have acer aspire m5640 desktop pc i want to load windows xp on it but its showing blue screen i from sata driver allso from floppy drive but it shows txtsetup file missing please give me the...
if u dont have orignal opreating systeam on u r pc then u can install xp u said u have sata hdd
1) check u r orignal set up is working properly for harddisk working . if it's not working check it by Herenboot it's third party sofware which boost up u r systeam for checking .
2)some time blue screen errors comes cuse CD is not good which u r using or , harddisk having bad sector or RAM problem while installing xp
3) try on of this option
2answers
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
2answers
Sata
You must disable the native mode for the SATA in setup mode.
***NOTE*** be sure that you have all of your drivers for the SATA and all drivers for windows xp before beginning.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
