One heavy piece like that will not allow the washer drum to come up to top speed when for its final spin at the end of the cycle.
Next time, instead of endless drying, put it back for a final spin in the washer with a couple of towels so that the water can be extracted properly.
Make sure the door mat is evenly distributed across your tub . Modern washers imply load balancing algorithms that stop spin if the load isnt evenly distributed across since if theres uneven load thare have been cases of irrelegur spin leading to damaged machines as well . So if u cant dry something thats not at all flexible tand cant
be twisted or folded so that the weight is distributed across the tub the washer is actualy preventing a machine damage . Try to put it evenly or better sun dry .
SOURCE: Dark Spots on clothes
There may be some pieces of mat stuck between the inner and outer drums. The quickest way to remove this is to remove the drain hose that leads from the drum to the pump and feel around the bottom of the outer drum and remove any foreign objects that may be stuck in there.
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
SOURCE: LG WM-3677HW dryer cycle does not dry and lasts for 3 minutes
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
And rate me pl ...........if helped.
SOURCE: Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
