Question about Miscellaneous
Does anyone know the location and part # of Water Inlet Valve for a Samsung Refrigerator Model RF323TEDBSR/AA. Nothing on-line and not shown on schematic.
I have researched this to ***** and there is no information on-line and my repairmen can't find the location either or the correct part #. I have two ice makers and water. Lower icemaker quit working and have done on of the trouble shooting. Samsung refuses to give me any information on this model and says go hire a Samsung Technician. We live in a small city and it will cost $100 just to get them here. The water supply connects in the middle of the Refrigerator about 3' off the ground. The Inlet Valve is not in the back of the refrigerator. Does anyone know the location or how to get to it and the part # for this Samsung Refrigerator Model? Greatly appreciate any help. Thank You
    Top Expert:
  • Miscellaneous Master
  • 54,386 Answers
Go To www.repairclinic.com and enter RF323TEDBSR/AA. With luck, you will be presented with a list of common replacement parts/assemblies and may be able to view a generic Samsung video showing disassembly with part/assembly identification.
Posted on May 30, 2018
Testimonial: "Tom; Thanks for the suggestion and that is a good site, but my model displays at least 5 different water inlet valves. The video shows the valves in the lower back panel. I have nothing there so it is not helping with my specific model. There is 01 through 04 plus my model that does not have any number, just AA"
    Passionate:
    Visited the website for 10 consecutive days.
  • 164 Answers
It's not the water valve
Posted on Nov 04, 2018
    New Friend:
EASY FIX!!!!! And you don't even need to cut power. For bottom ice maker if the reset works but no water, just do this. Remove the 2 screws holding ice make in bottom pull out. You will need to remove the small bottom top draw Unplug 2 wire clips. Now on back of fridge unscrew the 2 screws holding the small black water line cover going to bottom ice maker. Then remove the internal 2 screws holding valve. No need to unscrew the water line. Slowly slide out the insulated water line. You may need to unscrew the hold down clamp holding the line in order to pull this out all the way. Its like 10-12" long. NOW... Look into end and you will see ice. Use a heatgun or hairdryer to heat up this unit untill all ice is gone. Ice will be a solid shaft. Make sure you can see all the way thru the unit before you finish. It is now clear. Replace everything in reverse order and hit reset. WaLa! Water and future ice!!!
6ya staff
SOURCE:
MIKE major
  • 1122 Answers
SOURCE: Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Posted on Sep 22, 2008
lojacksdad
lojacksdad
  • 121 Answers
SOURCE: new water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Posted on Apr 13, 2009
Maytag317
Victor
  • 1136 Answers
SOURCE: Water Supply Line for Ice maker and Water dispenser is leaking.
Hi, The fitting either needs tightened or changed. Is this a brass or plastic fitting?
If the supply line is still ok and not brittle, you can go to your local hardware store and get the new fitting parts. If it is brass, be sure and get the brass insert that goes inside the tubing as well as the compression ring.
Please let me know if I can assist you further.
Vic
Posted on May 28, 2009
Anonymous
  • 53 Answers
SOURCE: Can't connect water line from the icemaker to the new water valve
the valves they have now only have push locks. so the only thing you need to do is push the water line in and it should lock.
Posted on Nov 05, 2009
Testimonial: "Even though the answer was not possible, it did answer the question about how the connection is made & that I may have to replace the water line."
Anonymous
SOURCE: Amana free o frost refrigerator
My fridge makes a loud rattling noise when turning off and on
Posted on Dec 29, 2009
How to change water valve for a Samsung Refrigerator Model RF323TEDBSR?
should be on back and on bottom might be able to get to removing lower front or back panel
Aug 21, 2018 | Samsung Refrigerators
Showing code 8E
This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
Ice Maker For Samsung Refrigerator Model RF323TEDBSR
Sep 26, 2015 | Samsung RF323TEDBSR 31.6 cu. ft. French...
Water dispenser drips
The water inlet valve needs replacing. It's located in the rear of the refrigerator and can be accessed by removing the cover (either cardboard or metal). The water line is attached to the water inlet valve. You can order the part online or purchase one from a local dealer.
Mar 08, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
Need to replace the water inlet solenoid
The Samsung side by sides and french doors have split systems meaning both freezer and ref have evaps. Your water reservoir could be frozen. They have DC heater that is attached to reservoir so it does not freeze, this could be your problem. The other problem that I have run across is the water line in the door can be frozen. If it is the door, you can check by locating where it enters the door, because it will have a quick disconnect. Disconnect water line and grab a cup and place cup under diconnected line coming from cabinet on the door and press or have someone call for water on fountain. Let me know if that helps. Thanks Logan.
Apr 07, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Nowater to ice maker
That is most likely the=> DA74-40149D Water Inlet Valve providing your model is a Samsung RS2630SH being defective on the ice maker side of the DA74-40149D Water Inlet Valve
Not your model number? Let me know, Thanks Sea Breeze
Mar 21, 2013 | Samsung RS2630SH Side by Side Refrigerator
Ice maker, seems like the water fills the ice tray w/to much water, runs into the ice container and I have large clumps of frozen water in ice bin.
The water inlet valve is bad and needs to be replaced.
The valve is located in back of the refrigerator. You can follow the water line that connects to the refrigerator right to the water inlet valve to help you locate it.
Here is a video that shows you how to change a water inlet valve on a refrigerator. Though the video may not be specific to your model all refrigerators are similar.
I hope you found my post helpful.
Aug 07, 2011 | Refrigerators
No Ice or Water
The water inlet solenoid valve orifice may be plugged. Locate the water solenoid valve where you connected the water line to. Shut off the water and then check this orifice and screen.
Apr 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
NO WATER
You may have a bad water solinoid valve.Or the screen located between the valve and inlet water is clogged.
Dec 05, 2007 | Samsung RS2630SH Side by Side Refrigerator
Open Questions:
Kaspersky tollfree Number 1..855,,536...5666 Kaspersky antivirus support number uques %Q%# Kaspersky antivirus support number 1..855,,536...5666 Kaspersky tollfree Number This KASPERSKY ANTIVIRUS USA phone number{ +1855 5365666} is ranked #2 out of 2 because 7,728 KASPERSKY ANTIVIRUS USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:855:,:5365666 is to reach the KASPERSKY ANTIVIRUS USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, KASPERSKY ANTIVIRUS USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KASPERSKY ANTIVIRUS USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I855 5365666 and ways to call or contact KASPERSKY ANTIVIRUS USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KASPERSKY ANTIVIRUS USA Calling KASPERSKY ANTIVIRUS USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KASPERSKY ANTIVIRUS USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KASPERSKY ANTIVIRUS USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KASPERSKY ANTIVIRUS USA's phone numbers against each other. Contacting KASPERSKY ANTIVIRUS USA in General While I855 5365 666 is KASPERSKY ANTIVIRUS USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I855 5365 666 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KASPERSKY ANTIVIRUS USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KASPERSKY ANTIVIRUS USA.
Nov 11, 2019 | Miscellaneous
Miscellaneous Logo
245 people viewed this question
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
