SOURCE: hoover 800 washing machine
take the cap of the top of the agitator you need a 10mm socket
on along extension bar undo the bolt in the bottom of the agitator and it will lift out replace by do-ing the reverse process
i have just done it better than paying $100.00 for a service call
for five minutes work
SOURCE: Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
SOURCE: Drum locking bolts - front loading washing machine
If the hole is in the rear cover of m/c, then it should be o/k, if it is in the side then it could have caused some damage.
Plz rate my solution.
Thanks.
SOURCE: I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
SOURCE: agitator for whirlpool washing machine
The plastic dogs are stripped inside the center of the agitator. To remove agitator pop off the top center cover(slot for screwdriver) There is a 7/16 inch bolt with standard thread, remove it and pull out agitator. Pull the agitator apart, you can stand on the bottom half and pull on the top, you have to reassemble it with the new dogs replaced(there are four in a package) Fairly simple, no special tools needed,
good luck.
