When it begins to spin like on number ten but when it gets to number nine it always unbalance it doesn't matter if you have a light load or heavy
SOURCE: Washer will not stay balanced on spin cycle no matter what size load.
The tub brace or spring may have come loose.
SOURCE: Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
SOURCE: washer will kick in spin cycle, but with any type
Good day,
Without the model number or make, makes it pretty hard to come up with a solution, but if it's not a Whirlpool, Kitchenaid, Roper, or Kenmore direct drive top loader,
Remove the front panel and check the belt and tensioner.
Also, on occasion, water, and or possibly oil from an oil leak out of the bottom seal of the transmission can get on the belt and cause slippage.
P.S. On older Whirlpool and Kenmore washers, they did use a belt and you accessed it from a panel on the rear.
Belt might need adjusted, or in some cases the clutch simply wore out. Not a practical repair.
SOURCE: my kenmore elite oasis top
It appears your load balance sensor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: I have tumble action washer, Kenmore model
It appears your clutch assembly has failed in this instance.
