Question about Sennheiser Audio Players & Recorders
I have a sennheiser set 830 -tv cordless an I need the batery B A300 3.7 v 150 mAh
    Top Expert:
  • Sennheiser Master
  • 55,370 Answers
Fixya does not sell batteries.
Posted on Jun 05, 2018
6ya staff
SOURCE:
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
The batery in my sennheiser hdr 170 only last 3 minutes
Sounds like a new one is required. Could be exhausted.
Nov 28, 2016 | Computers & Internet
Can't get my TV listening device to work
It looks like you may have a Sennheiser 840S. There is a t-coil option, however, you can plug in any standard headset to the port on the side and use the device without your hearing aids. It's port #5 on page 2.
SENNHEISER SET 840 06 09 Instruction Manual Page 2
Dec 04, 2013 | Sennheiser Set 840S RF TV Sound Amplifier...
Want to know the maximum battery size ,( be it 9 cell or 6 cell)in mha...please
I don't like to just ignore posts, but yours doesn't make much sense. You are asking about a battery FOR WHAT?
Nov 28, 2013 | Acer Aspire One PC Notebook
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
42 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
