Cell Phones Logo
Tiana bowser Posted on Jun 04, 2018
My phone says secure booting error 1009 on my LG Stylo how do I fix it or factory reset it
5 Related Answers
Anonymous
  • Posted on Aug 25, 2009
SOURCE: reset security code for LG KG270
kg270 securety code
Anonymous
  • Posted on Sep 05, 2009
SOURCE: I bought a phone from ebay, and the security code
on the touch keypad "dial" 1809#*365# to enter Engineering Mode and select 4-Master Reset. You'll lose everything stored ON THE PHONE but will retain SIM card stuff and of course SDMicro stuff. The phone itself will be in out-0f-the-box condition
Anonymous
  • 57 Answers
  • Posted on May 06, 2010
SOURCE: my lg cu575 has a security code. I need code 4 factory reset?
only by pro equipment .
Anonymous
  • 1932 Answers
  • Posted on Nov 25, 2010
SOURCE: trying to factory restor my
Try this
Dial *228 ,Then select option 1.This will reset the security code.That will be the last four digit of your phone number.
If this also doesn't work then you need to take the mobile to the nearest authorized service centre of LG and they will reset it.
Thank You
claudeinmo
Claude Kayser
  • 9098 Answers
  • Posted on Jan 05, 2016
SOURCE: Fix for internal storage on a lg g stylo from cricket
Troubleshoot issues related to low internal memory on your ...
support.sprint.com/.../Troubleshoot...internal-memory...
Sprint CorporationThis article helps you troubleshoot low internal memory issues on your LG G Stylo. You may have low internal memory issues if your phone is: Displaying low ...
Internal storage (ROM): LG G Stylo ' T-Mobile Support
https://support.t-mobile.com/docs/DOC-21750
T?Mobile US, Inc.Apr 6, 2015 - Learn how to view free space and free up storage on the LG G Stylo. Go to: Manage storage View free storage space Manage storage To ...
[PDF]User Guide (English) - Cricket
https://www.cricketwireless.com/.../lg-g-stylo/Cricket_LG_G_Stylo_User...
Unlock code for LG Stylo 6
Only the person that set the code can get into the phone. A hard Reset is the only way, scrub it clean and reload the OS. There is no magic way involving the IMEI number. If it says PUK Lock, that is a whole new level of grief!
You need to enable Wi-Fi Calling manually if you want to use it.
  1. Ensure your LG Stylo â„¢ 6 is powered off.
  2. Press and hold the. Volume Down button. then press and hold the. Power button. ...
  3. From the 'System recovery' screen, select. Factory data reset. . ...
  4. Select. Yes. to confirm.
Factory Data Reset (Powered Off) - LG Stylo 6 - Verizon
How to do a factory reset on my LG Stylo 4 MetroPCS
  1. From any home screen, tap Apps > Settings.
  2. If in tab view, tap General.
  3. Under PERSONAL, tap Backup & reset.
  4. Select or clear the following check boxes:
    • Back up my data
    • Automatic restore
  5. Tap Backup account and follow the steps to create Google backup account, if necessary.
  6. Tap Factory data reset.
  7. Review the warning message and select or clear Erase SD card.
  8. Tap Reset phone > Next.
  9. Tap Delete all.
  10. Tap OK.
Get LG Stylo 4 MetroPCS unlock code to use any network
Unlock LG Stylo 4 How to Unlock LG Stylo 4
https://www.unlockninja.com/unlock-lg+stylo-4
How to disable developer options on lg stylo 2
LGStylo2hardreset from the menu. Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the phone this way, you are prompted to re-enter the same information as when you first started your Android phone. Go to Settings > Backup & reset > Factory data reset and confirm. That should remove developer
My lg stylo powers on but powers back off saying Security error... how do I get it to power on & work properly
Reset back to factory...was this a firmware update?..I had this phone before ...
I factory reset data on my LG Stylo 2 and it now reads enter password on Startup
My lg did the same thing I had to call the mcaffee security hot line.
The 4 PIN number had to be reset buy them you will need to give them the email addres from when you set the phone up the first time. It's kindof a pain in the but. If you do a google search you will be able to find the support phone number.
Factory reset lg stylo stuck on Google verification
Must be buton in the screen "skip" or "registre later" or "not now" or similar, but then you'll can't using Google services.
2answers
Hard factory reset
Hi Tania
Sorry to hear that a full Reset didn't fix your problem!
Don't LG have an LG Shop or an Android Shop close by to get service like you do with the Apple Store.
Service is an important part of who you choose to purchase your phone from.
Cheers
LG Support Australia Customer Service and Technical Support LG Australia
Lg Service Repair Centers
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
