Question about Yamaha Full-Size Keyboard
Yamaha Clavinova CVP503. The problem gradually (4-5 days) became permanent. In those days, i had to power it ON and OFF 2-3 times and it worked. Then 5-6 times. Then 8-9 times as the days gone by.
After the 5th day I am in the following situation: After powering it on, only the display is working. No panel buttons interact, no leds above keys slide to L/R sides and back to center and keyboard does not produce any sound, although holding the last key down (C) and powering it on, starts initialization. Where should be the problem? At the speakers? At any capacitor? In the power supply cable? THX
6ya staff
SOURCE:
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Posted on Oct 15, 2007
Anonymous
SOURCE: Toshiba A105 keyboard
Aha, all 4 arrow keys and z key at the same time after MS windows update!!!
Posted on Dec 19, 2007
Anonymous
SOURCE: Denon DRA-25/25L Stereo Receiver.
Without looking at the schematics for this particular model, I'd surmise that the click is indeed a speaker protection relay. Generally this is fed by a number of different sense circuits that watch for power amp issues and/or excess speaker current and/or power supply output stability. Although the relays do indeed fail at times, generally it is not the relay that is at fault. If you have a scope and a schematic, you can check the various circuits that feed the relay for the exact cause. If not, you can do some experiments that might help deduce the problem: e.g. do headphones work when speakers do not, does the relay click on when no speakers are connected (or selected), etc. In my experience, it is most often the output transistor(s) in the power amp. But not always ;-)
Posted on Oct 15, 2008
Anonymous
  • 20 Answers
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Posted on Feb 15, 2010
shltech
SOURCE: Sharp LC37D44U Power LED was flashing green. TV
I had the same problem. all the service reset would only make the display come on for a few second with no "k" on the screen - only the channel would show up. I purchased a complete set of board for the lcd on ebay, and started swapping them one by one. The inverter boards were the culpret. Tele working 100% since that board swap.
Posted on Apr 08, 2011
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
Yamaha clavinova cvp55
Try resetting the piano.
Mar 05, 2014 | Music
Yamaha clavinova repair
I Bim
which clavinova model you have
Jan 19, 2014 | Music
I need a replacement board XE771 for my yamaha clavinova cvp-20
406-582-5849 if you want to talk about it. I have one here and I'm repairing it. Maybe if yours has part of the upper surface intact I can figure out how to fix mine from yours and fix yours at the same time and test it here
Apr 28, 2012 | Yamaha Full-Size Keyboard
Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Nov 17, 2009 | Yamaha Music
Yamaha clavinova CLP200 the amp has lost power
I might suspect that the volume control itself may have a break in the resistance element by your description. There can be many causes however including LOOSE CABLES. IF the unit has been moved recently, then a loose cable MIGHT be the cause. In any case, servicing iis required. If you are not familiar with electronic repair you will need to find an experienced repairman.
Nov 08, 2009 | Yamaha Music
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
Can I replace the pedal unit to the Yamaha Clavinova CVP-75?
I can't solve the problem, but just wanted to sympathize because I have the same problem. My pedal is broken on my Yamaha Clavinova cvp85a. It worked wonderfully for years but finally it broke.
I'd be in the market for buying a new pedal or fixing the old one. But I've not found any suggestions in any of these forums for either solution.
Jul 21, 2009 | Yamaha Music
Yamaha Clavinova CLP 260
hi...
Your L/R jacks in the back need to connect to the "line-in" connector on your sound card.
I think the jacks on the Clav are 1/4 inch. Go to Radio shack and ask for an adapter that will take two 1/4 inch plugs/cable and convert it to a 1/8 inch stereo plug.
The Midi connects From (keyboard) To (soundcard)
Cables are available at any music store
Jan 12, 2009 | Yamaha Full-Size Keyboard
Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Jan 04, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
109 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
