Ive seen this problem before on my dads drill. the selector knob probably broke on the inside. if so you'll need to get a new knob. I use ereplacementparts.com for my individual parts needs.
SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
SOURCE: Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
SOURCE: dewalt dw567
if i'm confused i'm sorry, but don't confuse and impact driver with a hammer drill
2 different tools altogether
SOURCE: I have a 1/2" Dewalt corded hammer drill, and it w...
it more than likely needs a new switch, to to Dewaltservicenet.com and you can download a breakdown with parts list.
SOURCE: Dewalt xrp stuck in hammer
I am assuming you are talking about
not being able to move the "Mode Control Collar" and unless you can
get it out of hammer mode, you will not be able to change the torque collar
either. If you feel comfortable taking it
apart AND its no longer under warranty, my best guess without seeing the tool will
be part# N026313 Gear Case Assembly. It costs about $80.00 US Hopefully its under warranty, if so
you can go to http://servicenet.dewalt.com/ServiceCenter/Search to locate nearest service center. Good luck Sorry I wasn
either.
you can go to
Good luck
Sorry I wasn
