Probably defective, you need to replace the screen or a cable inside of it https://www.sosav.co.uk/store/200-samsung
SOURCE: My Samsung Galaxy Tab says
You're in download mode. If you're not connected to USB, then pull the battery and plug it back in. This will restart your device.
SOURCE: My samsung galaxy tab from
When its off condition
do Volume Up + Power-button for 3 secs
you will see a screen with exclamation mark with android and some font written in Blue
Do wipe data using Home key to select and volume keys to navigate
then do reboot to system i think it shd fix your issue.
SOURCE: I have been trying to
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
SOURCE: I bought my Samsung Galaxy
It sounds to me like you have an issue with your Galaxy Tab's charging port.
Fortunately it is still under warranty if you've just recently purchased it.
Take it back to the store or contact Samsung for a warranty replacement. They may be able to help you recover items from the memory.
Hope this helped!
Thanks!
SOURCE: samsung galaxy tab 2 10.1 wgxa model GT-P5113 is frozen
Hold the power button down for up to 15 seconds. This should hard reset it. Not to be confused with erasing data.
