SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
SOURCE: Error code E004 and E003 on JUKI LU-1510N-7 and
HI THERE
1- CAN YOU PLEASE TELL ME MODEL OF CONTROL BOX?
2- IF SC500 OR SC510 MODEL SO E003 AND E004 MEANS
( YOU MUST MAKE SURE JACK FOR WHITE RESISTANCE BACK ON THE HEAD CONNET TO THE CONTROL TO DEFFINE THE MODEL WITH CONTROL.
( CHECK THE SYNCHRONIZER (CN31 ) FOR LOOSE CONNECTION ANS DISCONNECTION.
( SYNCHRONIZER LOWER POSITION SENSOR FAILURE YOU NEED TO CHECK WHETHER THE SYNCHRONIZER CORD HAS BROKEN OR SINCHRONIZER IS DAMGED.
IF YOU NEED MORE HELP PLEASE EMAIL ME AT ( [email protected] )
best regards
ashraf abozid
EGYPT - CAIRO
