SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
SOURCE: reset codes
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
SOURCE: i have a tv/vcr combo sansui tv with no remote and
Hi! actually most sansui are manufactured from china, so you should try the codes designated on china brand of tv"s.
SOURCE: Unable to pair a Philips Universal remote with Sansui TV
Hi
1032, 1051, 1052, 1054, 1061, 1075, 1079, 1091, 1140, 1157, 1173, 1203, 1209, 1232, 1237, 1258, 1287, 1337, 1339, 1340, 1375.
Regards
Phillip
SOURCE: how to program a universal remote for the Sansui
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
