SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
SOURCE: Washer/Dryer is not spinning
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to
the drive of the agitator is worn and needs to be replaced.Similar to
the drive shaft of a rear wheel drive v-8 car!
Could make this sound first, like a knock,knock,knock or klack, klack,klack
OR,SOMETIMES JUST NO SOUND AT ALL AND JUST NOT CONNECTED FROM THE TRANSMISSION TO DRIVE THE ROTATION OF THE TUB!
This means you need parts! and service!
How old is the washer if it is 10 years old or more I recommend being prudish about investing a lot of money in to it!
The newer models are so much more energy efficient, that they save you water,gas or electricity And detergent too!
They can pay for them selves in energy savings in a few years!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
